First post, by AGD Cougar
Ok, I am new to this so please forgive the ignorance. I have tried everything on the newbie's pictorial guide and so forth with no luck.
I am tring to run dosbox .63 on a windows mobile 5.0 device (ppc 6700). I forgot where I downloaded this version from but it does work. The problem i currently have is mounting. I noticed that when I started dosbox, it auto attempts to mount a drive for me but it fails. command is:
mount c "cf card\drive"
but it says director \cf card\drive doesn't exist.
I also tried manually with the help command and it does no good. I figured I would try to do it the faqs on this site recommended but also no good,
Thus i am stuck and would appreciate any help.
Thanks in advance
Reply 2 of 2, by Xelasarg
You probably downloaded it here:
http://n0p.averest-k.ru/?DOSBox_PPC (if not, you should do so, because it's by far the best PPC port).
You have to change the path in your dosbox.conf file (comes with DOSBox) to match your memory card's name. In my case (MMC card) it goes like this:
mount c "\storage card\DOSBox\Games" (i.e. I've put my games onto my storage card into the folder DOSBox\Games)
