copy command
First post, by Ravetracer
Hi there,
i've tried to compile some old pascal code from me.
The compiling works well, but after that, i have to link it
with 2 other files.
In the good old time, i've done it with: copy /b file.exe+anotherfile+file2
How can I do this in DosBox? It doesn't work at the moment.
My version is 0.65 under SUSE Linux 10.1.
Reply 1 of 6, by DosFreak
Yeah, DosBox can't do that. I believe it will work if you boot real MS-DOS in DosBox tho.
Make your games work offline
Reply 2 of 6, by MiniMax
Rank Moderator
Moderator
You can do the equivalent of
C:\> copy /b file.exe+anotherfile+file2 final.exe
from any Linux shell if you navigate to the DOSBox-mounted directory and issue a
$ cat file.exe anotherfile file2 > final.exe
_________________
Reply 3 of 6, by Ravetracer
MiniMax wrote:
You can do the equivalent of […]
Hehe, yeah right. I've forgot, that the drives are normal directories 😦 .
Hope this will work in future versions of DosBox, cause i wrote a little
batchfile to compile and link the programs.
But the workaround works fine too.
Thanks and greets from germany.
Reply 4 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
oh yeah. I intended to add that. There is a patch on sf.net which adds it, but I didn't like the way it was handled.
what is the syntax btw ? (and in which order does everything appear ?)
can stuff like
copy a+b
be done ?
Water flows down the stream
Reply 5 of 6, by MiniMax
Rank Moderator
Moderator
Qbix, the (partial) syntax is like the current CMD / copy command:
COPY source1+source2+sourceN destination-file
The /B flag is for binary copy (that is ignore CTRL-Z as End-Of-File marker)
The full syntax is a little more versatile. Check this link: http://www.microsoft.com/technet/archive/msdo … 1.mspx?mfr=true
_________________
Reply 6 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
thank you for the link MiniMax,
copy a+b
can be done apperantly.
The result will be called "a" in that case
