First post, by Hagman1983
The CD-ROM (or actually DVD-ROM) is having problem reading game discs with DosBox which leads to that I'm unable to install games from CD, not fast enought according to Game install programs. I've used all the commands for mounting the CD (DVD) player but none helps.
* ABIT KN8-Ultra Motherboard
* AMD64 4000+
* TwinMOS PC3200 DDR-DIMM 2048MB RAM
* XFX GeForce 7800GT 256MB GDDR3 eXtreme, PCI-Express
* Creative SB X-Fi XtremeMusic
* WindowsXP Pro (32bit)
* Sony DVD DWQ30AB2 OEM
Reply 2 of 9, by Hagman1983
All, basicly, but now I'm trying to install Top Gun Fire At Will. I managed to install an other flight sim, Fleet Defender, by taking all the contents of the CD and install through the HDD, but that worked only because the game don't need the CD while playing.
Reply 3 of 9, by eL_PuSHeR
Are you sure your CD/DVD drive is not broken?
Try making CUE/BIN images and mount them inside DOSBox using the imgmount command (or using some virtual drive like Daemon Tools or Alcohol 120%).
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 9, by eL_PuSHeR
Have you tried different DOSBox versions (CVS, etc)?
Have you tried -usecd <number> option?
Intel i7 5960X
8 GB DDR4 (2100)
Reply 6 of 9, by MiniMax
Rank Moderator
Moderator
I wonder if the answer to that question will contradict this:
_________________
