First post, by starik
mwahaha!
i'm trying to run soft-ice for dos 2.8 and dosbox crashes with:
terminate called after throwing an instance of 'char*'
Aborted
would something like soft-ice ever work in dosbox?
Reply 2 of 3, by jefferl
The older version of soft-ice work on dosbox 0.72
s-ice 1.03 work fine
s-ice 2.1 work fine
s-ice 2.5 & s-ice 2.64 after enter C:>s-ice
In dosbox status window show below message:
Exit to error:Illegal descriptor type0 for int D
The old full screen debugger
code-smith 86
Trace 86
TR (95% fine)
work fine in dosbox
freedos command line debug,
grdb (with source code) both work fine
http://members.tripod.com/~ladsoft/grdb.htm
Could someone add more dos-debugger information
to complete this thread?
