First post, by Chupo_cro
I have two videos:
- DOS: 640x400
- In-game: CGI mode 320x200
The idea was to first recode both videos to 320x240 XviD+mp3:
Filter: resize: 320x200, Expand frame&letterbox image: 320x240
Then I have two 320x240 videos with black areas above and beneath (targeting YouTube aspect ratio).
After opening the first one, setting Direct Stream Copy & Append segment, I am getting this error:
http://img81.imageshack.us/img81/5858/dosbox04mx2.png
Any ideas how to join these videos?
Chupo
Reply 2 of 4, by Chupo_cro
Thank you very much! Works like a charm 😀
Here's what I did:
http://img254.imageshack.us/img254/6826/dosbox05jl2.png
It's working although the framerate is changed to 69.999 after pressing OK.
No out-of-sync-sound, however this video is quite short, I wonder if there's a possibility to experience the sound-video desync when working with long lasting videos?
Chupo
Reply 3 of 4, by Harekiet
Rank DOSBox Author
DOSBox Author
Sound sync should be okay if you record longer pieces, dunno about chaining together a whole bunch of small ones that all have slightly different frame rates though. But you can always fiddle around with little shifts of the audio.
