Framebuffer
First post, by asdbla
Hi,
i have a Debian on a Arm926 with a 2.6.24 Kernel but without Framebuffer support.
Is there a possibility to run or compile Dosbox to work without Framebuffer suppport? I only want to run 80186 Code. I only need stdout for debug output, no graphics no sound or other special things.
thanks,
Sebastian
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
tricky. you would have to modify dosbox for that. or maybe run a virtual X server
Water flows down the stream
