First post, by dorrepaalm
When compiling a program using Borland Pascal the memory usage increases dramatically (from 60MB at start till 600MB end of compilation).
Sounds like a memory leak to me. The compilation speed is also very poor.
Any solutions?
Reply 3 of 9, by neozeed
I kind of 'found' the answer to this, I was having big problems with this too (a good day of running a program that keeps shelling out and I was ~1.5GB of ram in use!!!) Anyways it's the directory cache!!!!
Memory usage while compiling with Borland Pascal
There is a hint on this problem here...
It would seem that mingw's gcc on windows leaks like crazy....
in the file /include/dos_system.h
Change
#define MAX_OPENDIRS 2048
to
You can't completely disable it this way, and yeah it'll keep on leaking memory, but it's FAR less then before.. One insane build program would leak about 200-300MB in a minute, and now I'm leaking 17MB of ram in the same operation.....
I'm on Vista x64, gcc version 3.4.5 (mingw-vista special r3)
Reply 6 of 9, by neozeed
basically just keep running any compiler over & over.....
like this exciting program...
void main(){}
bcc x.c
re-run this a few times, and you'll see memory starting to increase.... the more complicated build steps (ie more headers, and anything pharlap involved since it's got so many step) you'll see it adding more memory...
I could have sworn I ran clipper 5.3 on this earlier and the exospace linker (it's pharlap 286...) would make it go nuts.... even simple programs like
? "hi"
Reply 7 of 9, by neozeed
I dont know if it matters that much, but that causeway linker & extender doesn't cause dosbox to leak...... Let me try MSC 5
edit MSC 5.1 doesn't explode out.... didn't the old borland 3.x stuff run in protected mode...? I vaugely recall something like that...
I wonder if it's programs that open & close files like wild in PM cause the issue.....
I'll have to test something further.
What is interesting is that eventually, depending on the OS, it'll over commit, and then the memory usage will drop down to 5-9MB!!!!!
I wonder if it's easy to outright remove all the file/directory cache?
Reply 9 of 9, by neozeed
robertmo wrote:
by the way, your link links to this thread
oops how did I manage that?!
DOSBox memory leak (use all my ram 'till it dies)
Thats the ancient thread...
with the quote of
No, but maybe it's something with the file caching. It's hard to do any real testing as the problem seems to be build-specific. […]
real testing as the problem seems to be build-specific. You could go
through the cvs builds thread on the dev forum to see if any of those
works.
From someone named wd wd
