First post, by T.J.
Hi!
I do hope someone can help me to solve this problem. I downloaded DosBox a while ago, since I wanted to be able to run some old DOS games. I installed it and everything went well, during the installation. However, when I clicked on the icon in order to run the program, the command window flashes really quick, and than there´s a searing sound, and my computer reboots. This happens every time I have tried to run DosBox. Thinking it was something wrong with the version I downloaded I tried another version....but with the same result. The versions I´ve tried, are 0.73 and 0.74. I´m running Windows XP.
Furthermore, I´ve also attempted to run DosBox via the command prompt, but with the same result.
Since this is the best Dos emulator (I´ve had it on a previous computer) I would really like to be able to use it on my current one as well.
Really hope someone here can help me. Thanks in advance!
/Tobias
If you believe in something really hard, it comes true.
Reply 1 of 3, by DosFreak
DOSBox cannot cause your computer to reboot. It's likely a video/sound driver issue.
Make your games work offline
Reply 2 of 3, by T.J.
Really? Because I haven´t had any problems with the graphic or sound card whatsoever. And this specific issue, only happens when I try to run DosBox.
Do you mean that there´s a general issue with my graphic or sound card, or just in connection with DosBox? Is there any specifications for DosBox which states what hardware it works with? Just asking since I haven´t any problem with any other program but just this one.
Thanks for trying to help! =)
/Tobias
