Newbie help
Reply 20 of 24, by tman
No, there is no config.sys there either. Sorry I don't have bochs installed. I just downloaded the source, and it fails to compile out of the box, seemingly requiring Carbon. The pre-compiled Mac OS X binaries seem very old and don't seem to run.
Reply 21 of 24, by IIGS_User
Dominus wrote:
Usually? Always depends on where such an image is... Could also be /volumes/dosusbstick/images/ultima/u5/floppy.img 😉
That is just path nitpicking and has nothing to do with the problem.
You are completely true, this is correct 😀
When placing the stuff into the user's folder, it can be shortened by ~/...
This is true, the latest Bochs Mac OS X version seems to be 2.1.1 (from 2004), the latest version of other ports seems to be 2.4.5, created in 2010.
I've no idea how to compile stuff myself.
Klimawandel.
Reply 22 of 24, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
via MacPorts you can "install" bochs (which means it will be compiled). http://www.macports.org/
But that may be overkill...
Edit... hmm, and if you are on OS X 10.6 it won't build for you...
see http://trac.macports.org/ticket/23938
Reply 23 of 24, by Great Hierophant
All IBM PC Compatible Ultima 1-5 floppy versions have disk-based copy protection. There is a program that will strip the protection.
