for example when I try to run "jetpack" it says: "can't find JETPACK0.DAT". When I look in the folder then it's in the folder..
another example. when I try to start the game called "boloball" DOSbox says: "boloball is missing som files
Missing: BOLOBALL.EXE BOLOBALL.OV0 BOLOBALL.OV1 BOLOBALL.0V2 BOLOBALL.OV3" and this is also the folder, it's the .exe-files I try to run.
I am using a HP Mini 110-1100 (notebook), with Windows7 starter 32-bit, 1 GB RAM and 1.60 GHz... another you want to know ?? but I can't see that this should be the problem.. I hope that the two examples could help you, so you maybe can help me 😀
@BasketFurry
I haven't change anything in the folders I have downloaded, just looked at them and thought "the missing files are there" 😖 or maybe, I haven't understood you right ..
