First post, by gavinwatson
Hi Guys,
I apologise if this has already been answered but I couldn't find a thread when searching.
I'm struggling to get custom configuration files to work.
I've created a duplicate config file with a different name and made the changes I need to mount the correct drives and run the game automatically. This custom config is in the same directory as the main dos box one.
Then I created shortcut on the deskop
Target: "C:\Program Files\DOSBox-0.74\DOSBox.exe" -conf systemshock1.conf
Start in: "C:\Program Files\DOSBox-0.74"
Unfortunately it refuses to use the new config, it just uses the stardard one.
I've also tried -userconf and -userconf -conf and every other combination.
I've read through all the internet guides on this and the dosbox manual and I can't see what I'm doing wrong.
Really keen to get this working as I want to set up multiple short cuts and config files for different games.
Hope you guys can help, 🙁
Gavin.
