First post, by TerminusEst77
I don't know if my problem is specifically DOSBox/Dfend Reloaded related or not, but I want to get some help via this forum so I can , if not solve the problem, at least be able to confidently discount DosBox/Dfend Reloaded as the source of the problem.
I recently downloaded and installed the current version of Dfend Reloaded and have had success with all the games I've tried on it so far (like Warcraft II and Flight of the Intruder).
I'm running Windows 7 Ultimate 32-Bit with a NVIDIA GeForce GTx 760 GPU; via a HDMI cable I'm running both Visual and Sound to my Kogan HD TV and both have been working find for these DOS games.
Recently, I picked up and installed the War of the World's RTS game - I followed the directions given in this post ( http://www.thewaroftheworlds.com/messageboard … MessageID=28465 ) in order to enable the in game music to be played.
However, after I have done this, I found that I can no longer play the sound for *any* of the DOS games through the HDMI/Kogan TV - interestingly enough, though, I **can** still get the sound to play via plugging in a set of headphones through the normal headphone jacks.
I suspect that the "_inmm.dll Ver. 2.38" program has either rewritten or corrupted a Registry File, or it has somehow disabled something *within* DOSBox, preventing it from recognising the existing of the Audio/HDMI connection.
Therefore, to eliminate DOSBox/Dfend as a possible issue, can anyone advise of any diagnostic tests or config file edits I can run to either re-establish the Audio/HDMI connection or see if something within DOSBox has been corrupted and needs to be replaced.
Thanks in advance.
