Scanlines
First post, by uniracers
When using the tv2x, tv3x, scan2x, or scan3x scalers for 320x200 games, if I set aspect = true, the scanlines are not even. If I set aspect = false, it looks fine. I assuming this has something to with the way things are scaled. Is there any way get even scanlines with the corrected aspect ratio?
Reply 1 of 4, by Tertz
Try higher resolution and higher multiplicator - this will reduce the effect of aspect correction. To get fully correct image of 320x200 you need not aspect correction by dosbox, but a video mode wich has x and y multiple to 320x200 like 640x400 for example, - such were possible on CRT and maybe will look good on LCD with small dots (<=0.27 mm). Use output=surface then.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 2 of 4, by leileilol
aspect=true and a high res like 1280x960 helps and so does a smooth video output like opengl, direct3d and ddraw (on some cards), which can help against the stretch artifacts.
Reply 3 of 4, by TeddyTheBear
You can also try changing the fullscreen resolution to match the scaled resolution and let the GPU or monitor hardware handle scaling to higher resolutions from there. You might have to create custom resolutions in the GPU driver.
However I would first recommend trying the DAUM builds that have support for shader scalers.
Reply 4 of 4, by Tertz
It's similar to what I've said above. But monitor should show video mode as is, not GPU deal with it. So aspect=true will result in distortions, like blurriness for example.
Yamaha YMF7x4 Guide
