DOSBox Compilation Guides Testing
General information and assistance with DOSBox.
Postby DosFreak » 2018-5-08 @ 20:07
I've released compiled binaries of the 5-2-2018 SVN here:
https://drive.google.com/open?id=1G13rk ... 3aMO8U9mvV
Go to the "Releases" folder and you'll see builds for Windows NT3.51+.
If you test the Mingw-w64 releases on NT3.51,95,NT4 then make sure to download the updated MSVCRT from the mingw-w64\tools\binaries folder. Replace the msvcrt in your system folder
The 64bit build of DOSBox requires core=normal
I'm looking for people to compare against 0.74 on as many different hardware and OS configurations as possible and all of the features supported by vanilla DOSBox.
The mingw and mingw-w64 releases with all of the different OS versions are basically the same so don't bother comparing them against each other, but do compare mingw tvs mingw-w64 builds.
User avatar
DosFreak
Re: DOSBox Compilation Guides Testing
Postby DosFreak » 2018-5-10 @ 12:18
Hmmm mabye I should put SHADERS!!!! in the topic title.... (that would be a lie but still....)
https://www.youtube.com/watch?v=dATZsuPdOnM
User avatar
DosFreak
Postby gandhig » 2018-5-19 @ 10:39
I will be able to do some testing(around 30% output) from next weekend. Thanks for persisting with these guides, especially for beginners, even though no support seems to be coming your way.
User avatar
gandhig
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 2 guests
