First post, by Kaega2
I'm hoping this is something known and easy to fix.
I installed Duke Nukem 3D from an ISO image through DosBox by mounting the image and running the install file. If I launch DosBox on it's own I can see the Duke3D folder and run the game just fine.
I want to be able to open the game through LaunchBox. For some reason when I go into my folder for DosBox I can't see the Duke3D folder through Windows. All other folders show just fine.
In case it's important I mounted the ISO like this from DosBox.
imgmount D c:\Dos\DN3D\DN3D.cue -t iso
Had c:\Dos\Programs mounted as C (that's where all my games are)
And ran the install.exe from the D drive.
I'm using the Daum DosBox from January 27 2014
