Reply 22 of 22, by jez
realnc wrote:
keenmaster486 wrote:
So this method scales everything to an as-large-as-possible box on your modern widescreen monitor with the aspect ratio of a 4:3 CRT, with the characteristic black bars on the sides.
The OP is asking for no scaling at all. For a 320x240 game, that means a small image in the center surrounded by huge black areas, like you get when using "surface" output with a "none" scaler.
Well, it does the scaling that's done by the scaler. So normal2x will give you double that size for example. But what it doesn't do is then additionally scale the thing to the size of the entire screen in fullscreen mode. I don't know why the other output modes do, actually, if that's what the scaler's for.
== Jez ==
