First post, by theelf
Hi, well, exactly this, is possible to change resolution and machine inside dosbox?
for example, most of the time i just use
fullresolution=original
output=surface
machine=vgaonly
For vga games
But some games i want to play in hercules mode for example, i try machine=hercules and fullresolution=720x350 but no luck, dosbox dont change on the fly
Same for EGA games, for example i create 322x200 at 60hz with scanlines, and i tried fullresolution=322x200, but same, no change
Of course, if i different config outside dosbox, i get perfect hercules and EGA
My idea is if possible to do inside dosbox with commands
Thanks for any help
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
In SVN you can use the CONFIG command to write settings and then restart: config -writeconf -r
Any setting changes you made will be saved and used after restarting, including settings that don't take effect immediately like machine type and memory size.
Reply 2 of 2, by theelf
Thanks a lot! great tip, i did not test latest SVN, i was using stock 0.74
New config options are great, i just need to make some batch files (setvga, setega, sethercules, etc), and problem solved
Again, thanks for your time and reply
