First post, by robbo007
Hi, does anyone have the compiled copy of Dosbox with the debugger enabled for MAcOS 10.14.x? I'm trying to compile but get errors. Can't seem to get it to work on Windows XP either? I get a SDL.dll error.
Cheers,
Rob
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
on XP, the debugger version can be placed in the same folder as normal debugger and then there should be no problems, as it uses the same dll files.
Water flows down the stream
Reply 2 of 4, by robbo007
ok, Do I need to install and SDL libraries on XP? I've tried registering the sdl.dll with reg32svr but it does not work. I've placed the dosbox debugger in Windwos/system32 where the windows debug.exe is and I still get the same error about the sdl.dll.
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
No I added a debugger to many in my previous reply.
The debugger version should be placed in the same folder as the normal dosbox version.
