First post, by Peter Swinkels
Hi,
As stated in the subject line, I am trying to use the DOSBox debugger on a laptop which does not have a full keyboard. This means there's no pause key to be found (and no it's not FN+some other key) and I am unable to pause DOSBox for debugging.
While changing the keybindings in DOSBox does give me a pause key the debugger doesn't seem to recognize it. Other than finding an external keyboard to use, I see no other solution. Does anyone have any suggestions?
Thank you.
Do not read if you don't like attention seeking self-advertisements!
Did you read it anyway? Well, you can find all sorts of stuff I made using various programming languages over here:
https://github.com/peterswinkels
Reply 2 of 3, by ripsaw8080
Rank DOSBox Author
DOSBox Author
You can remap what activates the debugger; alt-pause is just the default binding. You're probably not using the mapper the right way: don't change the binding on the "PAU" event, change the binding on the "Debugger" event.
Reply 3 of 3, by Peter Swinkels
Those are all good suggestions! Thank you, every one.
ps:
The laptop was borrowed. Now using my own pc again. 😀
