First post, by whocrazy
Hi.
I'm trying to run a program cup386.com for unpacking old dos executables, but when I run it under dosbox, it freezes.
Is there a fix for this?
Thanks.
Reply 1 of 17, by llm
what executables - maybe someone know already how to unpack them
no idea (cup386 don't seem to like EMM386) - but have you tried UNP from http://unp.bencastricum.nl/ - well known, works under dosbox and maybe able to unpack you exe
Reply 2 of 17, by whocrazy
Yes, UNP does decompress executables, however, I was just curious as to why CUP386 crashes under dosbox. I tried turning off XMS, emms and umb, but CUP386 still falls over.
Reply 5 of 17, by whocrazy
I don't even get any errors when trying to use the program.
In fact, merely typing "cup386" without any switches simply freezes the dosbox session and I had to ctrl-F9 to shut it down.
Reply 6 of 17, by firstrose
cup386.com is not for DOSBox. DON'T use it under DOSBox. Use it under pure DOS.
cup386 itself should runs under real mode, then it will enter 386 protected mode and starts unpacking.
DOSBox can not offer real mode.
That's why it freezes.
Reply 8 of 17, by firstrose
jmarsh wrote on 2020-07-22, 04:00:
All DOS programs start in real mode. If DOSBox didn't support real mode it wouldn't be able to run anything.
It's not real "real mode", but v86 mode.
Privileged instructions / Sensitive instructions can run under real "real mode".
DOSBox doesn't support them.
Reply 9 of 17, by jmarsh
DOSBox executes all DOS programs in real mode unless they explicitly enable V86 mode/protected mode. It's an emulator, it doesn't try to execute the privileged instructions on the host system.
How do you think it runs on non-x86 systems like arm or powerpc if it's using V86 mode?
Reply 10 of 17, by firstrose
jmarsh wrote on 2020-07-22, 06:23:
Excuse me, but do you really know what I am talking about?
A guy asks why cup386 doesn't run in DOSBox and I am trying to give the answer.
The point is cup386 is written before more than twenty years ago. It runs only on x86 system and uses x86 privileged instructions.
So I think my words are based on x86.
Reply 11 of 17, by jmarsh
Yeah I know, because I wrote two emulation cores for DOSBox - one for x86_64, and another for PowerPC. So trying to tell me it can't run real mode programs is a waste of time.
Every DOS program starts in real mode.
When they switch to protected mode, they use privileged instructions to thunk back and forth to real mode to communicate with DOS and hardware.
How do you think any of that works for all the games DOSBox runs if DOSBox doesn't support it?
Reply 12 of 17, by Wengier
The reason that the program is not supported by DOSBox is that DOSBox is for running DOS games, not DOS programs. So there are a number of DOS calls not emulated by DOSBox because they are not used by DOS games.
Reply 13 of 17, by Akuma
whocrazy wrote on 2019-08-18, 08:45:
Hi. I'm trying to run a program cup386.com for unpacking old dos executables, but when I run it under dosbox, it freezes. Is the […]
Hi.
Thanks.
Yes, you can use cputype=386_prefetch
Hangs during unpacking is a mix of unimplemented DOS call and anti-debugging traps.
You will hit those anti-debugging traps in real DOS too, btw.
Dosbox works fine for most unpacking problems, I rarely go into real DOS at all.
Akuma
Reply 14 of 17, by ripsaw8080
Rank DOSBox Author
DOSBox Author
CUP386 calls DOS to execute the packed program and then monitors the unpacking process, so problems can arise from the packed program rather than the unpacker. I suppose that's not unusual for unpacker programs, but it's worth noting that what is being unpacked affects the result. Lightweight test: with an LZEXE-packed executable, I find that the /1 option seems to work okay in DOSBox 0.74 and SVN with default settings, but cputype=386_prefetch appears to be needed for the /3 option.
Reply 15 of 17, by kjliew
firstrose wrote on 2020-07-22, 10:35:
It is better not to give any wrong answers if you do not know the stuffs. BTW, jmarsh does know his stuffs and I reaffirmed that your answer of "DOSBox cannot execute privileged instructions for x86 real-mode" is non-sense.
CUP386 belongs to the class of programs that heavily manipulates platform quirks and undocumented CPU/DOS behaviors similar to SoftICE for DOS. It is a universal unpacker that employs techniques of code tracing (with built-in debugger) to find the unpacked code/data of any unknown EXE packers. It is not uncommon if emulation may have failed to implement the behaviors for such class of programs to function properly.
Reply 16 of 17, by BloodyCactus
dosbox has a lot of trouble with a lot of these old tools of this kind, softice, cup386, a lot of cryptors (gardian angel). sometimes normal core works ok. normal works better than dynamic for these. some old stuff you need prefetch, some dont. you need to experiment, but dont expect miracles getting a lot of these old packer/unpacker/scrambler tools running.
