First post, by Guest
Hi there
I was trying to get Hell - A Cyberpunk Thriller to run on dosbox but it tells me following:
You don't have enough memory to run Hell: A Cyberpunk Thriller.
Although you have enough available core memory to run the game,
you need at least 1,457,600 bytes (150 pages) of available
expanded memory.
when checking with mem i see that i have 63424 Kb free XMS
I checked my config to see if i can find any entry about xms but only found the entry to enable or disable xms and ems... i also searched the forum for any clues..but after searching for over half an hour i decided to post and ask.. so if anybody can tell me how to increase the XMS i'd appreciate it...
Reply 2 of 5, by Alexsource
ummmm... you can't. You can increse overall memory, but i think you've already reached the top (64 mbs). Memory emulation works sort of like this (anybody cares to make a better explanation than this?):
* If you have both xms and ems enabled: half and half each.
* If you only have xms or ems enabled: evrything goes to the one that is enabled -> this seems to be your case.
I don't have the game, so i'm not sure what you can do... Try disabling xms too and see what happens. It can also be that the game is confused at the total amount of base memory free, and it's displaying an erroneous error message. You can use loadfix to try to correct that...
Finally, it can also be a cpu core thing. Try the different cpu cores first than anything else 😉
Hope that helps
Reply 3 of 5, by Markus
Don't mix up expanded memory and XMS.
Expanded memory normally refers to EMS, but might be also used for extended memory.
While EMS and XMS were techniques to manage a computer's extra memory, extended memory wasn't managed at all, it was the applications task to manage it.
So you should try your app with XMS and EMS disabled.
Reply 4 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
well dosbox does like the later emm386 and qemm manager a sort of sharing.
Anyway try 0.61 as i lowered in 0.62 the amount of memory you can have to 63 mb
but a game wanting that much memory will probably not run very fast.
Water flows down the stream
