I BOOT WINDOWS 3.1 UNDER DOSBox-0.62
Reply 20 of 28, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Yes, just do it (I think you have rights for DOSBOX Guides forum).
I also already got tired 😀 😀 😀 today of another often occuring topic (HD images) and made a guide for that .
Just an idea: Maybe it would be also good to have in future version of DOSBOX a bigger FAQ like they have for example in Exult project in addition to README... Any volunteers... 😀
Mirek
Reply 21 of 28, by MiniMax
Rank Moderator
Moderator
"Yes, just do it" - damn, I had hoped that one of you would do it 😀 Actually, I was hoping that we could all do it using the DOSBox Wiki. We already have a good explanation of the imgmount command with detailed examples of how to make a bootable hard disk image. I guess I should try to incorporate the info from your latest post into that?
The FAQ is also growing. Have a look. I hope to be able to break it up into smaller pieces (like this) during the weekend, making it easier to add new Q&A to the document.
MiniMax - the Wiki Gnome
Reply 22 of 28, by mirekluza
DOSBox Moderator
You can use/extend anything what I wrote... As for WIKI - good idea - but I think it would be also good to have this topic in DOSBOX Guides (so that people coming here see it immediately and it is found when searching).
Well, I will have to have a look on what is in WIKI sometimes. 😀 Till now I only briefly looked there a few times. maybe I can save myself occasionaly some explaining here ...
Mirek
Reply 23 of 28, by lwc
Hey MiniMax, thanks for helping me give a real upgrade to the Imgmount Wiki page.
But I noticed you changed all the links for image files to z:\ (e.g. "z:\>imgmount c c.img"). Don't forget that it's impossible to hold personal files on z:. It's important to note that one must mount first and mount d: and not c: (because you want to create the hard disk image on c: later)!
Also, you gave "Example #1a" which is for mount and not for imgmount.
Reply 24 of 28, by MiniMax
Rank Moderator
Moderator
@lwc, you are welcome. Hope I didn't overdo it.
About the Z-thing - you are right. I wanted to examples to be as real-life as possible, including a drive prompt (e.g. Z:) instead of "...". But I see the problem of trying to mount a "c.img" file from Z: 😀
And that's the beaty of the Wiki - I make an error, some else can easily correct it.
_________________
Reply 26 of 28, by DosFreak
Run DosBox using normal core and mouse support will work fine.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
