First post, by Mastergabe2009
I'm trying to mount my Elder scrolls arena game and it wont respond to the d key
for example I put:
mount c c:\elderscrolls
except every time I press d it wont input d
so it comes out to
mount c c:\elerscrolls
I know next to nothing about computers, so if you can give me instructions on how to fix this like I am an old senior working with a computer for the first time, that would be great.
Reply 1 of 3, by Mastergabe2009
If it helps, I think the reason is because I changed the controls in Arena so I can use WASD to move. I tried changing it again but CTRL-F1 does not let me access the keyboard functions anymore.
Reply 3 of 3, by jmarsh
Running "config -r -resetmapper" from inside DOSBox will delete the saved key mappings and close DOSBox, so when you restart it the keys will be back to defaults.
Alternatively if you used the windows installer there is a "Reset KeyMapper" shortcut in the start menu under DOSBox->Options (which is what Qbix was talking about).
