First post, by hardl
Can I only use different .conf-files via the command line or is it possible to include the xxx.conf of the app or the alias?
Reply 1 of 5, by IIGS_User
When using Terminal application:
  1. open DOSBox with right-click, choose "Show package content",
  2. go to "Contents/MacOS/", drag the including file "DOSBox" into the Terminal application,
  3. enter "-conf ", drag the configuration file into the Terminal application to get its path,
  4. press enter to execute the command.
Klimawandel.
Reply 4 of 5, by Monotremata
Use a front end that handles that for you. DBGL allows you to setup multiple DOSBox 'profiles' and each one can point to its own conf file. You can apply these to the game profiles too, so each game/app can run with its own custom setup.
