First post, by mike_canada
When the real MS-DOS starts on an old computer, config.sys is processed before autoexec.bat but I want to know if there is a way I can run some config.sys commands.
I'd like to be able to set the values to the following variables:
FILES
BUFFERS
STACKS
And is there a way to set the DOS environment size? On a real DOS setup, I can execute command.com /E:xxx
The reason I ask is because I'm troubleshooting a DOS networking application and I think it has alot to do with the environment.
