First post, by Guest
I had a question about the sound. Everything works fine and all and all my games run great but I was wondering if its possible to turn off or mute the sound from the games.
Editted by eL_PuSHeR
Changed original post title to a more comprehensive one. 😎
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
@Guest - you have two options:
1) Mute your sound as usual (Control Panel -> Sound). This will mute everything - not just DOSBox.
2) Use the DOSBOx mixer command (check out the DOSBox ReadMe for details).
_________________
Reply 2 of 3, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
See DOSBOX.CONF, option "nosound" in section "[mixer]". This should do the trick:
nosound=true
Just remember that you set it like that before coming to complain in a few weeks that sound does not work in DOSBOX. 😀
Mirek
Reply 3 of 3, by lwc
I don't think "nosound=true" or even mixer would help him.
I think it's pretty safe to assume that he refers to muting the game while inside a game - by using an internal shortcut (like you do to increase the frameskip, capture a screenshot or a sound, etc.).
