Reply 20 of 22, by DosFreak
Just put CLS at the top of the [autoexec] section.
If you don't want to do that then you'll have to modify the DOSBox source and recompile.
This isn't important enough for DOSBox to have a feature to enable/disable.
Make your games work offline
Reply 21 of 22, by prometh
DosFreak, very clever. Works well too
And to finish off this thread, MiniMax's suggestion to use multiple -config's solved my cascading problem. However, an automatic implementation would be awesome too.
Reply 22 of 22, by MiniMax
Rank Moderator
Moderator
prometh wrote:
And to finish off this thread, (<snip>)
Finish off? I am still waiting for an answer to the my last post and the result from using that test.conf.
_________________
