Reply 21 of 41, by robertmo
- l33t++
svga_s3
w/o -24
btw does it happen in both fullscreen and window?
and is the error message exactly the same with and without -24?
Reply 22 of 41, by raer
- Newbie
I think there's some confusion here. Maybe I screwed up some information too...
The demo crashes with the -24 switch. I does NOT crash without it.
I tried what you said and the demo runs ok. It uses fake highcolor mode in the Minnie mouse part obviously and all frames are now of the same size.
What are you trying to achieve by the tests btw?
...find some video captures of old DOS demos here...
Reply 23 of 41, by robertmo
- l33t++
wrote:For me it crashes both with and w/o the "-24" parameter.
Reply 24 of 41, by raer
- Newbie
Hmmm. Sorry then. It seems I screwed up there earlier... 😒
What about the "-24" crash? Is this the demos fault or is it DOSBox that b0rks out, or the S3 card, or whatnot?
I wasn't able to disassemble the code. It seems to use an unknown packer and IDA Pro doesn't like it...
Reply 25 of 41, by robertmo
- l33t++
and what is this about?
wrote:WTF! That worked. Thanks!
Reply 26 of 41, by raer
Reply 27 of 41, by robertmo
- l33t++
wrote:I have a small program which can solve this problem ...
Don't ask me why ...
This program is to solve another game's problem and I am not the author.
ok, now i wonder what was coolhaken talking about. I guess he tried the game only once, and only with the fix and it worked, cause it always works and fix does nothing for this game.
Reply 28 of 41, by raer
- Newbie
Well. IDA Pro tells you that the TSR does something to INT 15h and 1Ch:
public startstart proc nearjmp short loc_10116loc_10116:push cspop dsmov ax, 351Chint 21h ; DOS - 2+ - GET INTERRUPT VECTOR; AL = interrupt number; Return: ES:BX = value of interrupt vectormov word_10111, bxmov word_10113, esmov ax, 251Chmov dx, 102hint 21h ; DOS - SET INTERRUPT VECTOR; AL = interrupt number; DS:DX = new vector to be used for specified interruptmov ax, 2515hmov dx, 115hint 21h ; DOS - SET INTERRUPT VECTOR; AL = interrupt number; DS:DX = new vector to be used for specified interruptmov dx, 116hint 27h ; DOS - TERMINATE BUT STAY RESIDENTstart endp ; CS = current program segment; DX = last program byte + 1seg000 endsend start
1Ch is the Timer so it might be some speed fix like that one for old Turbo Pascal code...
Reply 29 of 41, by ripsaw8080
- DOSBox Author
wrote:What about the "-24" crash? Is this the demos fault or is it DOSBox that b0rks out, or the S3 card, or whatnot?
I explained why the demo terminates with an error when the -24 switch is used in my first comment. The ungraceful nature of the termination appears to be the demo's fault, but the authors probably didn't worry too much about graceful termination for a problem they likely didn't have.
As for your mistakes, miscommunication, or whatever about the demo not working without the -24 switch, or that coolhaken's attachment was somehow effective in fixing anything... well, I suppose I should not write what I'm thinking.
We'll have to wait for coolhaken to comment on what problem the attachment was supposed to help with...
Reply 30 of 41, by raer
- Newbie
wrote:I explained why the demo terminates with an error when the -24 switch is used in my first comment. The ungraceful nature of the termination appears to be the demo's fault, but the authors probably didn't worry too much about graceful termination for a problem they likely didn't have.
I understood that. The question was if the 24bit mode should be available or not. Is it in the VESA standard and should the card support it or were the coders just plain wrong?
Reply 31 of 41, by h-a-l-9000
My understanding is that in 24-bit modes the bytes are arranged more or less like this:
RGBRGBRGB
32-bit:
RGBXRGBXRGBX
where X is unused. In the latter you can address one pixel with a 32-bit access. Trio64 and maybe earlier seem to have a 24-bit mode. I'm not sure about Trio64V+. If it has one then it's hidden.
1+1=10
Reply 32 of 41, by coolhaken
Ahhh ... I am sorry for my mistake.
I tried this demo twice only. But I must have forgotten to add "-24" in the 2nd test.
There are too many replys in a day. 😵
Later on, I found that boot to real DOS can solve this problem.
Set cycles to about 30000 and don't press "Alt-F12" when running it.
"Toontown -24" works.
Reply 33 of 41, by raer
- Newbie
wrote:Later on, I found that boot to real DOS can solve this problem.
On real hardware? What machine, what graphics card?
wrote:Set cycles to about 30000 and don't press "Alt-F12" when running it.
Does not work for me.
Reply 34 of 41, by ripsaw8080
- DOSBox Author
I assure you that booting DOS is not going to make 24-bit color modes magically appear in DOSBox's S3/VESA implementation...
FYI, the demo will ignore the -24 switch if it doesn't find VESA 2.0, and you will know this because it does not say "Using VESA 2.0 TrueColor mode" at startup and instead suggests that you can use the -24 switch, even if you did use it. You can create this condition by using a SVGA machine type other than svga_s3. The problem is not "solved" if the demo is ignoring the switch.
Reply 35 of 41, by raer
Reply 36 of 41, by ripsaw8080
- DOSBox Author
wrote:If I'd be able to decompress it properly I could maybe make a 32bit color mode patch... :'(
A Google search for "pmwunlit" should turn up some help with that. The decompression, not the patch. 😉
Reply 37 of 41, by s3freak
- Newbie
wrote:I recently posted my Custom S3 Trio patch a few days ago where I patched it to include 24 bit colour - I did it experimentally. Having tested this demo with the -24 parameter, the demo looped successfully and when I disabled 24-bit colour, it crashed out like raer said. I never knew that my patch would come in handy one day!
This is the demo working in my patched DOSBox. Let me know if you are interested in downloading my build and I will send it to you in a private message, provided that the boards let me do so.
http://www.youtube.com/watch?v=QCsY0wRHUh4
Link to my patch thread. Once downloaded, you can study how my patch works. It took me ages to get 24 bit colour in general (Windows 3.1, VBETest, etc.) to display properly.
VIDEO CARD Custom S3 Trio Patch (DOSBOX)
When I used UniVBE with my real S3 Trio, it enabled both 24-bit and 32-bit versions of True Colour.
My 486 is my real DOSBox, as well as my customised DOSBox!
I am not very active on VOGONS, please send a private message if you need a quicker response!
Reply 38 of 41, by raer
Reply 39 of 41, by ripsaw8080
- DOSBox Author
To use IDA, first make sure the version you have supports linear executables, because not all free versions do. Then you'll need to strip the linear executable portion out of the decompressed executable, because the extender portion confuses IDA. The idea is to keep everything starting from the LE header mark and discard everything before. If you're not comfortable with manually extracting the LE then there are stubbing tools like SB.EXE in the DOS32A package that will do the job for you. An LE can't be executed directly, but you can execute it with an extender (e.g. DOS4GW TOONTOWN.LE) or bind an extender to it.
