Reply 21 of 27, by gulikoza
Doom also works fine here. I commented all the if blocks in risc_x64.h and added a LOG_MSG to make sure the new code is used.
$ ./dosbox
DOSBox version SVN
Copyright 2002-2015 DOSBox Team, published under GNU GPL.
ALSA lib confmisc.c:768:(parse_card) cannot find card '0'
ALSA lib conf.c:4185:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
ALSA lib conf.c:4185:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1251:(snd_func_refer) error evaluating name
ALSA lib conf.c:4185:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:4664:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2209:(snd_pcm_open_noupdate) Unknown PCM default
CONFIG:Loading primary settings from config file ~/.dosbox/dosbox-SVN.conf
Memory sizes above 31 MB are NOT recommended.
Stick with the default values unless you are absolutely certain.
MIXER:Can't open audio: No available audio device , running in nosound mode.
ALSA lib seq_hw.c:457:(snd_seq_hw_open) open /dev/snd/seq failed: No such file or directory
ALSA:Can't open sequencer
MIDI:Opened device:none
reg_memaddr
reg_memaddr
memaddr
reg_memaddr
memaddr
reg_memaddr
reg_memaddr
memaddr
memaddr
memaddr
reg_memaddr
reg_memaddr
memaddr
reg_memaddr
memaddr
Seems to work fine 😀
I'm afraid I don't know much about *BSD...but if it happens in normal core as well, then it's not related to dynrec.
Maybe you can do a strace or something similar and figure out what dosbox is waiting for?
http://www.si-gamer.net/gulikoza
Reply 22 of 27, by vext01
I've not had time to look into the slowdown thing, but I think you can safely treat it as a separate issue to the unhandled memory reference.
Do you plan to commit your changes, or do they need a code review etc?
Reply 23 of 27, by gulikoza
That's for the devs to decide 😀
@Qbix: there's also one issue that has been (at least) partly solved in SVN on OS X - core=dynamic causes segfault...I can provide the updated patch if needed.
Reply 25 of 27, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
And I can probably find some time to test this again - I'm sorry, it's one of the things I tend to forget that *I* needed to test and confirm... Tralalala 😉
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 26 of 27, by gulikoza
V3...removed some redundant ifs() and added some comments to hopefully clarify what the code does.
