First post, by videogamer555
With normal2x and normal3x interpolation, it does "nearest neighbor". WIth any of the others (such as 2xsai, and supereagle) it uses a special technique to guess the interpolated pixels in a way that does not smooth the brightness levels. However, I think linear interpolation would be good in some situations. So here I'm propoosing a new interpolation method in the next SVN version of DOSBox. It is 2x linear interpolation, and should be called "linear2x".
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
I assume you mean bilinear interpolation.
Which wouldn't be difficult to code, (I probably have the code of it in one of my local dosbox trees).
but is very similar to what the hardware opengl scaler does.
Water flows down the stream
Reply 2 of 3, by videogamer555
Have you added bilinear interpolation yet?
Reply 3 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
no, as i said. opengl does that already for you ?
Any reason why it isn't enough ?
