First post, by vish2648
Hello,
I am trying to interface microprocessor to display "FIRE" on seven segment through MASM. In order to establish communication from PC, I am using AllowIo.exe to establish communication. I have used the following command
-- AllowIo 0xd800 FIRE.EXE
If I execute the following command I am getting the error "This Program cannot be run in dos mode"
Reply 4 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
DOSBox is for DOS games.
1. that program is not a game
2. it's not for DOS either as you can see from the error message
(3. use DOSBox 0.74-2 but that does not change 1.and 2.)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
