First post, by eoredson
The following is trapped by DOSbox coldboot:
  DEF SEG = &HFFFF
CALL Absoulte(0)
DEF SEG
but the following warmboot is not:
  OUT &H64, &HF0
why not?
(I am using qb45/qb64)..
Links to my MUD
Dndbbs executables
http://www.filegate.net/pdn/pdnbasic/DND50A2E.ZIP
Dndbbs source
http://www.filegate.net/pdn/pdnbasic/DND50A2S.ZIP
Dndbbs upgrade (10/15/2019)
http://www.filegate.net/pdn/pdnbasic/DND50A2U.ZIP
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
DOSBox doesn't support actual rebooting (hot or cold) with the usual PC methods; at most they only cause DOSBox to close. In SVN you can use a "config -r" command for an actual restart.
As for the port-based reboot method, since it would only close DOSBox, how would supporting that be useful for playing games?
Reply 2 of 2, by eoredson
No reason, I just thought it was interesting to note..
Links to my MUD
Dndbbs executables
Dndbbs source
