First post, by Agathosdaimon
I have noticed something recently installing some games in dosbox, which perhaps has always come up but i havent noticed it before: when installing SVGA Air Warrior v1.13 today (outside of dosbox) during the install a message comes up :
"The CONFIG.SYS file was not found on the install drive, A copy has been automatically created on drive Z"
how and why is this happening? i was not aware the installation would even be aware of a drive Z, as i just mount only a drive C (my games folder) and a drive D (cdrom drive), where exactly is drive Z and why is there not a config.sys file found, is this typical?
i was thinking maybe this is location of the dosbox.exe program but i found no config.sys file there. Am i supposed to have a config.sys file present on my mounted drive?
Reply 1 of 1, by Gmlb256
Agathosdaimon wrote on 2021-10-16, 07:56:
Very likely due to DOSBox not needing CONFIG.SYS like real DOS. Drive Z within DOSBox contains useful utilities such as mounting physical folders, CD and floppy images as virtual drives.
Try creating a dummy CONFIG.SYS within the mounted C drive to see if that solves it or not.
Anyway if the game works fine then you shouldn't worry about this.
