First post, by mrfusker
Hello.
I have a problem by saving a game in Manchester United - The Official Game. I'm using dosbox 0.65, and I have mounted a local directory as my floppy drive (my computer doesnt have a floppy drive). MUFC cant accept the local directory as a floppy drive! What should I do?
Reply 3 of 12, by eL_PuSHeR
Rank Moderator
Moderator
mount a E:\U-Spil -t floppy
Drive letters A and B are usually reserved for FLOPPY DRIVES.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 7 of 12, by wd
Rank DOSBox Author
DOSBox Author
Most likely some low level disk access, might/might not work when
booting msdos using disk images and having that game disk mounted
as image as well.
Do you happen to know if the game disk itseslf can be booted? Like
command.com is present there.
