First post, by Neoda
Hi, Whenever I try and run Screamer in Dos box, I mount the cd drive and the hard drive, as I did when I installed it. Whenever I try and run it however, it always says cannot open file DATA\GEN.DAT . I've stopped it from being read only, however it is still archived if that could affect it. I've tried running Screamer with VDMS and Sapucdex, and it works fine on the first level, but on Mountan Pass and Lindberg it always crashes in the same place, with or without music and sound. I've tried older versions of Dosbox and the same problem come up.
Reply 1 of 8, by MiniMax
Rank Moderator
Moderator
Exact commands used to mount drives, and start the game please.
A listing of what is in your top-most directory on the DOSBox C-drive would be nice too.
_________________
Reply 2 of 8, by Neoda
mount c c:\SCREAMER
mount d E:\ -t cdrom (I've tried the other two aswell)
Dos box opens happily, and then I try and run screamer, at which point t comes up with the exact words "Cannot open main file C:\SCREAMER\data\GEN.dat"
I've checked and the file is there. As said before the game runs under VDMS with Sapucdex, but crashes at the same point on Lindberg and Lake Valley (corrected from mountain pass) and occasionally on the first map. I've tried most things, and it still crashes
Reply 4 of 8, by wd
Rank DOSBox Author
DOSBox Author
Basic mistake: mixing mounted drive paths with real drive paths.
Try this:
create a C:\GAMES directory (there you should put all dos games to),
then copy the whole C:\SCREAMER directory into C:\GAMES so you
have a directory C:\GAMES\SCREAMER
Now in dosbox, use "mount c c:\games"
when you change (in dosbox) to c: and type dir, you'll see a directory
"SCREAMER". Compare this to your old mounting. Now go into the
directory SCREAMER (still in dosbox) and start the game.
Reply 5 of 8, by SysGOD
i agree with WDs posting, but you also should check your sreamer.cfg in the main directory, if there is some mismatch with your settings.
btw i know your problems with VDMS. the game crashes for me on every track with hi resolution.
if you get screamer running with dosbox try the dynamic core and increase the cycle settings above 40k, but with a 1.5 GHz Pentium Centrino you would get no smooth gameplay at all.
Reply 8 of 8, by goethe
Open and edit screamer.cfg in your screamer directory
By example: I have screamer in root folder of unit D:
My screamer.cfg is :
d:\ d: d:\ d
This is for running installed Screamer with not cdrom from drive D
Screamer found DATA\GEN.DAT 😁
This is for a Screamer installed in Screamer folder in drive C
c:\SCREAMER c: c:\SCREAMER c
Sorry english is not my first language
