Problem with COM port.
Reply 20 of 30, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Yea, you can map any realport anywhere.
0.65 has at least one serious bug in the serial port - try a CVS build. If your hardware has some simple RS485/RS232 adapter chances are low since it needs proper timing.
1+1=10
Reply 21 of 30, by _ivan_
Thx Hal.
I'll try it later.
So i should type
serial2=directserial directport=COM1
i will try the 0.65 version but if it dosent work how do i download a cvs build. Do i have to compile it? Any guids here? Which CVS do u recommend?
How about cycles i am using a laptop Intel M techn. 1,4Ghz
core=dynamic????
cycles=3000????
anything more i have to configure?
Reply 23 of 30, by MiniMax
Rank Moderator
Moderator
Ivan, do a seach for CVS, and you should fine a sticky thread with all the info you need. But as wd said, better wait for the upcoming release of a new DOSBox. I don't remember the timeframe, but it should be soon.
Edit: The CVS thread - DOSBox SVN Builds
_________________
Reply 25 of 30, by MiniMax
Rank Moderator
Moderator
Ivan, the "with the interface" part sounds like you have downloaded ykhwong's (???) DOSBox. He has made many changes to the standard DOSBox, so you should ask him about the irq_int10 thing.
_________________
Reply 27 of 30, by _ivan_
Hal, i used your version on your website. The latest one for seriall.
Do u have any suggestions on what cycles i have to use and which core setting?
As i wrote above: I use an seriell interface that needs to run under win95/98 or DOS with MAX clock of 233 mHZ i have an Intel P M 1,4Ghz.
anny other suggestion on what i can try. I am getting the irq_int10 thing but the program still says that it can't find any cable communication.
Reply 30 of 30, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
You can try my build with ocbus.
Re: Direct serial port working
(try with and without the ocbus word)
Those OBD protocols may need very exact timing though which cannot be provided by DOSBox and the serial port driver.
