Netscape under DOSBox?
First post, by Neville
I know, I know, this is a game emulator, but I was wondering, since installing Windows 3.X is possible, if that version of Netscape I located on an old CD (v4.08 for Windows 3.1) could work under DOSBox. My guess is that it should work, although first I need to enable internet access under DOSBox and Windows 3.X. How can I do that? Do I need any particular drivers or Windows 3.1 has them already?
Reply 2 of 13, by Neville
Aw, forget it. Just checked my favourite frontend and seems that DOSBox only supports the IPX network protocol. This means that even if I install winsock, the TCP/IP network protocol for Windows 3.X it won't work.
Reply 3 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The modem emulation uses TCP. Theoretically it could work if there is something that accepts PPP connections on a TCP port.
1+1=10
Reply 4 of 13, by Neville
Mmm... Is there any frontend out there that allows to see / change the modem configuration? I'm a dummy when it comes to command line stuff, and I can't see those settings in DBGL or D-Fend.
Reply 6 of 13, by Neville
Thanks.
Reply 8 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
No that's in the betatesters forum
1+1=10
Reply 10 of 13, by Neville
No success 🙄
Step 1: Creating a profile with modem on, OK
Step 2: Installing Windows 3.11 + PCNET Family driver for Windows 3.X + Microsoft TCP / IP protocol, OK
Step 3: Installing Netscape Suite v4.08, OK
Step 4: Trying to configure TCP / IP from values obtained from IPCONFIG /ALL, Not sure if OK. Concepts are not exact over the years, and I may be filling the wrong values there.
Step 5: Creating a BAT including the NET START command followed by WIN.COM, OK.
Step 6: Restart Windows 3.11, Windows returns network error ( depressed: ), Netscape initialization fails miserably, I go for a coffee.
Reply 11 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Why would you think dosbox emulates such hardware? I was talking about a serial PPP connection AND you have to find the thing that PPP can connect to.
The Windows network stuff doesn't work in dosbox DOS, booting from an image may work around this.
1+1=10
Reply 12 of 13, by Neville
Ouch. 😵
I got those drivers from another web, they said it worked on virtual machines, so I though I should give it a try.
Anyway, I think I'm letting this as it is now (miserable failure), mainly because I'm a dummy when it comes to network real computers as well, and also because I just messed the D.O.G. profile and now i can't even run Windows 3.11.
Case dismissed.
