First post, by actuarius
I installed this game on my computer through dosbox, and have video and audio. However, when I actually try to view a game, it is like everything is in slow motion. I changed frameskip from 0 to 10, and that didn't seem to do anything. I am not really sure what other things I can try to make the game run at a normal speed. Also, the sound plays, but there is a constant beeping that occurs. Any ideas as to what settings I can mess with that might help these problems?
Thanks so much.
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
open dosbox.conf
look for cycles=3000
change that to cycles=max
look for core=normal
change that core=dynamic
save the file
run dosbox
Water flows down the stream
Reply 2 of 3, by actuarius
Thanks for the help Qbix.
I changed cycles to max, which made them 2500, so then I made it 15,000 and that made the video run at normal speed. The sound is still messed up -- hard for me to describe other than there is like a very fast pulsing in addition to the normal sound output.
