First post, by Spideyfan
I'm able to run "Night of the Hermit". But it is very slow. I have increased cpu cycles and frame skip.
I have also edited some things in the dosbox CONF file.
But I still have the problem. Any suggestions?
specifications:
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Processor: AMD Athlon(tm) 64 Processor 3000+, MMX, 3DNow, ~2.0GHz
Memory: 1024MB RAM
Page File: 405MB used, 2054MB available
DirectX Version: DirectX 9.0c (4.09.0000.0904)
Soundcard: Realtek AC97 Audio
Videocard: NVIDIA GeForce 6600
Reply 1 of 2, by LoneLines
Night of the Hermit is an AGS game, it should work with Win98 compatibility mode without the need for DosBox.
Give it a try...
Edit:
Ok, downloaded the game, you need to rename Hermit.exe to ac2game.dat and then run ACWIN.EXE
No compatibility mode needed for this and it works fine under WinXP.
Good luck!
LoneLines list of workarounds for various games in DOSBox:
http://ADogsBox.jellofishi.com
