Reply 60 of 132, by Neville
And finally, RAINE.
I've tested the latest DOS version available, v0.42.4. Works fine, but performance varies according to the game driver used. Taito and CPS1 games are playable, but not CPS2, at least not in my humble Athlon64.
Reply 63 of 132, by butterfly
Quite a few PC Engine/Turbografx emulators, Atari Lynx and many others. The question is. Is that really useful or is it purely trivial?
[EDIT]
DOS version of MESS for example.
I gotta feeling this thread is becoming quite dispersive.
Reply 66 of 132, by Neville
Tried several GameBoy emulators...
1) KiGB v2.01 - Works fine and emulation is 100%, but it is a bit slow:
2) Boycott v0.55b - Allegro crash.
3) GB97 v2.937 - Emulation is less accurate than in KiGB, but the games run way faster and are more playable, even if it feels a bit too fast (auto-frameskip maybe?). Sound quality is also lesser.
Reply 67 of 132, by butterfly
That's super-cool. On the other hand I dad no chance in making Resident Evil: Director's Cut, X-Men Mutant Academy, Resident Evil Gun Survivor work with AdriPSX.
But stlll... look at this MESS:
IBM PC / MSX / MSX
GameBoy / EuroPC / EuroPC
IBM PC XT/ Spectrum / C64
DOS MESS 0.89
None of the above can be considered playable, except for ELKS and GWBASIC (those aren't games though)
Reply 69 of 132, by butterfly
The speed isn't even close to the real thing on my system
Windows XP
Athlon XP 2400+ 1Gig of RAM
DOSBox 0.70
I don't know about other PC's or other versions of DOS-MESS. The games run slow and skippy, that won't allow you to play. Furthermore, I experienced some problems typing (i.e. what I type won't match what I'll see on the screen after I typed it) but that was a known issue at that time.
If you can, I suggest that you try it out so we'll have one more opinion (and maybe some advice).
And you'll have *nix running inside DOSBox, although in a tricky way...
Reply 70 of 132, by Neville
I have to say my experience matches yours.
I have an Athlon64 3400 with 1 Gb of RAM, and I've tested the same version of MESS with the Amstrad CPC464 driver.
It takes forever to get started, even to load AMSDOS. Don't want to imagine how slow more complex drivers will be.
I think it runs even slower than that NeoGeo specific version of MAME I tried some weeks ago. And that one was very slow.
Reply 73 of 132, by Neville
I knew I was forgetting something... C64.
Tried VICE v1.12 (the DOS port is still updated). Works well if slow-ish, I should try CCS64 later.
Reply 75 of 132, by eL_PuSHeR
Rank Moderator
Moderator
Are the two last images from "La aventura original"? Cool game. 😎
Wow, I am feeling nostalgic now. 😁
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 76 of 132, by Neville
The last three are. Text adventures are great to test C64 emulators because joystick replacement in C64s is a bit tricky, and these games don't use a joystick.
For all those who haven't hear of this game, back in the old days there was this little Spanish group, Aventuras AD, who made some great text adventures. If only they had translated them to English, they would be classics of the genre. "La Aventura Original" is a Spanish remake of "Colossal Adventure", but with very cool graphics.
Reply 77 of 132, by MiniMax
Rank Moderator
Moderator
I remember Colossal Adventure... Played the real Fortran-version in glorious yellow-on-brown colours on a Dasher DG-210 terminal.
What now?
xyzzy
Nothing happens.
_________________
Reply 79 of 132, by angrylion
GBA emulation is also possible under DosBox 0.71. Use no$gba 2.4c (DOS version). This emulator can be found here: http://nocash.emubase.de/gba.htm
I recommend that you put the attached .CFG file in the same directory as the unpacked emulator for maximum performance. I must admit that compatibility is great:) nearly every rom ran fine for me. But it is very slow on my PentiumIV 3.0 HT. You would hardly find any pleasure playing games this way, except maybe puzzles or turn-based RPGs. No$gba also automatically switches to 800x600 and a game you play is shown in the small window. You can scale the output to higher resolutions (press numerical "-" for menu) but it may (or may not) have some impact on speed. You can also try to enable sound support in the menu (it is disabled in my .CFG).
Below you can see screenshots from Need for Speed Carbon Own the City, Mario Kart - Super Ciruit, Doom II and Lufia Ruins of Lore (the last one in scale2x mode).
Seems like Nintendo DS also shows something under no$gba in DosBox. But it acts slower than a snail. It gets ages even to show some initial menus. Besides, no stylus emulation and no 3D I suppose. Here's a screenshot of New Super Mario Brothers.
    NO$GBA.CFG
    2.13 KiB
    236 downloads
