First post, by ADDiCT
Inspired by another thread on VOGONS, i digged out this classic shooter, and installed it in DOSBox 0.70. The game runs quite good, even the 3DFX mode is working (with Ykhwong's build, of course, although it's quite slow compared to software mode).
But: no matter what i do, i can't get CD-Audio in the game. The game has a MIDI soundtrack, which works OK, but i can't select CD-Audio in the ingame setup. I just have "MIDI" and "None" entries for the music. I remember the CDA tracks working in, for example, Dungeon Keeper, so i think my setup is OK. I'm playing from a BIN/CUE image, and the Audio Tracks are picked up by EAC, so the CUE seems to be OK. Any ideas?
Reply 1 of 8, by njaydg
Assuming that your image is created correctly ( data & audio tracks present ) are you sure you're doing the imgmount to the .CUE file? Because if you do it to the .BIN then no audio track is played...
Reply 3 of 8, by ADDiCT
OK, in the meanwhile i tried mounting the CD in DOSBox in every way i could think of. I tried the "usecd" and "ioctl" parameters, the "mount" command with the image mounted in Daemon Tools and with the original CD, and the "imgmount" command on the CUE. Just to be sure, i started Dungeon Keeper, which also has CDDA, and the audio tracks worked. Anyone?!
Reply 5 of 8, by ADDiCT
I think both. When the game is starting, it says "Extreme Assault CD found in drive e:" (i have c: and d: mounted as hd's). In the game, there is a "sound setup" menu. Only two options are selectable: "MIDI" and "No music". I assume there should be a "CD-Audio" option, but i'm not sure about that.
Edit: I did some more testing, and tried to run the game under XP with the VDMSound/DGvoodoo combo. CD-Audio still won't work. Without using SAPUCDEX, the game won't even recognize the CD.
Reply 7 of 8, by ADDiCT
Ehm... You got me there. I have no idea how to debug inside DOSBox. I presume i'd need a debug enabled DOSBox build, right? If there's any documentation available on the debugger, i could try to do it. But i think i don't have enough knowledge about DOS coding (or coding at all) to be really helpful with debugging...
Reply 8 of 8, by ADDiCT
Necroposting in my own thread! Man, a lot of stuff has happened since this thread started. Anyway, CD-Audio in Extreme Assault works great in DOSBox 0.74. I think the game has to be installed with the "recommended" install setting. Music can then be switched to "CD Audio" from "MIDI" in the game options menu.
