First post, by bz-mof
...although the database shows supported since 0.58.
I tested it with different PCs, both with WinXPprofSP2 and around 2GHz.
With Dosbox, the game has problems displaying the texts correctly (no different colors in EGA mode/text completely missing in HI-mode (guess VGA)). Without Dosbox, thess problems do not occur.
But it has a timing problem, always. When you have to start the first task after starting the countdown, the red bar in the lower right does not start to move/grow. Suddenly it is just completely there. But you have to press a key when it is running through the middle of its end-size, so you have a problem...
