First post, by m_gol
I installed mentioned EuroPlus+ program on Windows 3.11 fresh install (on DOSBox, of course). There is one big problem - when I try to add a new user, program runs and tries to find a database "EURODATA.MDB" in cd folder "D:\EURO\PL\BIN". EP+ should find it itself on inserted CD and run, but it asks for the file location. When I tell it when it is located, there is an error:
"Driver's SQLSetConnectOption failed
Driver not capable.
Disk I/O error."
It happens both when I locate this file od HDD or on CD.
I tried the following CD mounting configurations (I tried emulating directly from actual CD drive and from virtual one located on HDD):
mount d _PATH_LOCATED_ON_HDD_ -t cdrom
mount d _PATH_LOCATED_ON_HDD_ -t cdrom -usecd 0 (it doesn't work at all)
mount d _MY_CD_DRIVE_LETTER_ -t cdrom
mount d _MY_CD_DRIVE_LETTER_ -t cdrom -usecd 0
mount d _MY_CD_DRIVE_LETTER_ -t cdrom -usecd 0 -ioctl
mount d _MY_CD_DRIVE_LETTER_ -t cdrom -usecd 0 -noioctl
All of them returned the same error. 🙁
EP+ program works fine even at Windows XP - my problem is that I use Windows XP x64 Professional which does not support 16-bit applications.
Any ideas? I'd be grateful. 😀
P.S. I've got original learning English program - EuroPlus+ Flying Colours - dedicated to "Windows 3.1, 3.11 or newer", recorded on 3 CDs. I also own an original Polish version of Microsoft Windows for Workgroups (v 3.11) on 10 floppies (1.44 MB each of them). I managed to install this Windows 3.11 on DOSBox 0.71.
