Soccer Kid
First post, by fak
I try the play Soccer Kid on DosBox(0.72)
But it gives an error massage:
Soccer kid cannot run with an EMM driver
Please remove EMM driver from config.sys
What should i do?
Reply 9 of 9, by wd
Rank DOSBox Author
DOSBox Author
If you don't wanna type that every time you start the game, you have to
check which dosbox.conf is loaded (usually the one in the installation directory
of dosbox, where dosbox.exe resides as well) and change the (already present!)
entry ems=true to ems=false.
