First post, by sjjot
Hi , can anyone help me ?...I can get the Duke3D heading on DOSbox but I don't know what to type to get to the setup screen . Any sort of help would be useful . Thanx in advance , sjjot .
Reply 2 of 13, by sjjot
leileilol wrote:
.......why's it always the build/wolf engine people?
setup.exe
I tried this but it didn't work . When it showed this...c:\>...I typed ...setup.exe...& it went to the next line with just beeping colon & nothing else ...like this one only horizontal . Any other ideas please ?
Reply 3 of 13, by eL_PuSHeR
Rank Moderator
Moderator
Do you have output=surface in your dosbox.conf file? If so, try anything else like overlay, ddraw or OpenGL.
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 13, by avatar_58
What did you mount as "C:"? "\Duke3D"?
You could always run setup in windows and just run the actual game in dosbox, but again it should work just fine if everything is in the right spot.
Reply 10 of 13, by sjjot
Ok , i found an easier way...no typing ! I found this port called eduke32 . I just put that & my duke files together & i'm running . I appreciate your help , thanx .
Reply 12 of 13, by MiniMax
Rank Moderator
Moderator
/me gets ready to hand out aspirins.
_________________
