First post, by inverse_paradise
hey there, trying to get my theme park game to run on dosbox but i've run into a brick wall..
i've tried running setup.bat from a backed up iso of theme park on a virtual drive and i get a prompt saying...
Unable to change to: config.
Illegal command: main.exe
i've even tried running the game from the cd and i get the same problem.
i'm running dosbox v 0.72 on windows xp home edition. somehow i don't think the technical spec. of my computer will help. let me know if i'm wrong.
grateful for any help i can get.
Reply 3 of 3, by inverse_paradise
Qbix wrote:
have you installed the game ?
i'm trying to using dosbox...
catchaserguns wrote:
i Found that when you have programs with very simular names this happens. You might want to change the name of your file.
what do you mean? i can't rename it on the iso or cd cause, well, they're write protected.
