Fifa 96 on Dosbox (HELP)
Reply 21 of 23, by HYRO
Found the problem, You have to use FAT16 file system format!
It is not DOSBOX but pure MS-DOS in my case but it worked!
I couldn't run the game, every time I had "File read error" message, I was using MS-DOS 7.1 and FAT32 partition, I decided to change FAT32 file system to FAT16 and installed MS-DOS 6.22, FIFA 96 is alive now, no "file read error" message any more and it works perfectly!
Try it and let me know if it was the problem in Your case.
Reply 23 of 23, by HYRO
Ok so I have an update, the problem is not the filesystem, when all starts to work with fifa96, I wanted to change my cd-rom driver that takes less memory, after doing that fifa96 again stops to work.
I've used my other hdd with ms-dos 7.1 and windows 98 installed on fat32 partition and used cd rom driver that was added to my dos 6.22 and it works again.
I've attached the driver with this post.
    CD-ROM.zip
    12.69 KiB
    87 downloads
    MS-DOS UNIVERSAL CD-ROM DRIVER
