Jagged Alliance, install fails
First post, by metalfan
Hi,
ive copied the cd to drive and run install.exe from dosbox, but the installer aborts with:
Can't open file: QICKSTRT.SAV (Free translation from the german error)
Jagged\ Alliance is the cdroot, so the file is there...but why does the installer abort?
Jagged\ Alliance/ROOT/QICKSTRT.SAV
greets
Reply 3 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
yeah that is probably not going to work
most installers want to be run from D and install on C (and D mounted as cdrom)
So try this
mount c /home/myuser/dos
mount d "/home/myuser/dos/Jagged Alliance" -t cdrom
d:
install
Water flows down the stream
Reply 5 of 8, by manio
Hello,
i am experiencing the same problem and although your post helped me to get pass the "Can't open file QICKSTRT.SAV" error, now it stuck at a new one reading : "Can't open file DOS4GW.EXE for output!".
The file IS located at the /ROOT directory of the game files, and although i tried to mount it from the virtual CD-ROM and from hard drive (both with -t cdrom options) it couldn't find it.
im running WIN 7 64bit and trying to install to c:/program files (x86)
any help please ?
Reply 7 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Use the 60 seconds guide from my signature. And don't bump four years old threads...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
