First post, by AmyGrrl
I have lost my original install disk of this, but I still had an old RAR of the my Direct Access v5.1 Folder. My problem is I have DOSBOX v0.72 installed and setup to auto-mount a folder and boot into Direct Access and all works fine except when I try to run a game a different game. I can select a game and play it without problem. Then when I am done playing and exit the game it boots right back to the Direct Access Menu, now if I select a different Game to play it loads the Game I had just played. Now if I exit this Game it will finally let me select a new Game, but the same thing will happen again if I exit this game and try to load a new game.
So I'm wondering if this is a problem with DOSBOX emulating Direct Access or maybe my copy of Direct Access is broken. I really wish still had my originals to do a fresh install.
Anyways, thanks for any info provided.
