First post, by hibbs
I am having trouble getting syndicate to run
I have a newer laptop with the following
1.8gHz processor (centrino dual core i think)
4 gHz ram ddr3
vista ultimate 64-bit os
nVidia 8800 gts graphics (1 gb video mem i think)
I d\l dosbox 1.72 or .72 w\e, the newest I believe
Syndicate runs great to start go through the menus and lauching the mission, however once i begin to move an agent the control display (?) starts listing hundreds of illegal read errors...
I would love to play this game again, maybe im putting the files in a bad location. I made sure the path was all in folders with 8 characters max, under C:\games\syn the file to launch is main.xxx . can anyone suggest a fix? thank you!!
Reply 1 of 2, by MiniMax
Rank Moderator
Moderator
I think you are doing it correctly, but maybe reading my 60 Seconds Guide to DOSBox will help?
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 2 of 2, by mefistotelis
You have downloaded Syndicate from Abandonware site or P2P network.
Instead of downloading CD image of "Syndicate Plus", you've downloaded a single ZIP/RAR file, which contains some strange release.
Your release is simply broken. One or more of the data files are damaged.
You can buy original CD ob ebay if you really want to play it.
